10 years agoHow can I generate time limited sof file?
Hi, My design is not uses cores without licence, but I need to generate "time limited" file to demonstrate. Can I do it?
10 years ago --- Quote Start --- Thanks, kaz, I understand it. But I don't want made any changes in my code, I just want generate another file. Is it possible? --- Quote End --- I doubt it is possible as altera doesn't provide such option for field use. You may drive the configuration pins to clear the fpga from outside fpga or inside(using counter idea)
