8 years agoHost Pipe example : failed set arg 0, error code -30
Hi, All new on the forum, thanks by advance for your reading and answer. problem : I am currently trying to run the demo code for opencl host pipes on an Arria X (https://www.altera...
8 years agoIs the text exactly the same? Channels for communication through network ports also have a similar section in the BSP.
Other than that, the example should work fine. I haven't tested it personally, though, since my board does not support those channels.
