8 years agoHost Pipe example : failed set arg 0, error code -30
Hi, All new on the forum, thanks by advance for your reading and answer. problem : I am currently trying to run the demo code for opencl host pipes on an Arria X (https://www.altera...
8 years agoI checked the BSP, there is the two lines you mentionned into "board_spec.xml" file.
Do you have an idea where the -30 error can come from in the host pipe example from Intel-Altera, except a wrong BSP ?
