8 years agoHost Pipe example : failed set arg 0, error code -30
Hi, All new on the forum, thanks by advance for your reading and answer. problem : I am currently trying to run the demo code for opencl host pipes on an Arria X (https://www.altera...
8 years agoCheck the "board_spec.xml" file in your BSP for a set of lines like the following:
<channels>
<interface name="board" port="host_to_dev" type="streamsource" width="256" chan_id="host_to_dev"/>
<interface name="board" port="dev_to_host" type="streamsink" width="256" chan_id="dev_to_host"/>
</channels> If these lines do not exist, your BSP does not support host channels (which is the most likely case).
