8 years agoHost Pipe example : failed set arg 0, error code -30
Hi, All new on the forum, thanks by advance for your reading and answer. problem : I am currently trying to run the demo code for opencl host pipes on an Arria X (https://www.altera...
8 years agoHost pipes require support in the BSP. As far as I know, only Altera's reference BSP supports host pipes right now. Unless the BSP for your board supports host pipes, you are not going to be able to use it.
