9 years agohold timing and clock frequency considerations
hello all, two questions for the experts: 1. why hold time is not frequency depended? 2. will it be reasonable to assume that design that fits timing requirements with 100MHz clock fr...
9 years agoTiming analysis checks to ensure the setup time is not violated. If you use a slower clock, the setup required period is the same, but the time between potential bit changes is now longer. So if it didnt break the setup timing before, it wont now.
