NSuku1
7 years agoHLS not generating the VHDL output
Hi, I designed a matrix block using Intel HLS and compiled.. But why does it generate the Verilog output instead of VHDL ? How to make it to generate the VHDL output? Please help me. Thanks, Ni...
NSuku1
7 years agoOh! NO... I was expecting the hls component will output VHDL and I need to integrate with another component written in VHDL. Now, how can I integrate VHDL with Verilog?
Nivetha
- HRZ7 years ago
I integrated a VHDL module inside a Verilog top-module once a few years ago using Xilinx ISE. I would assume it would work the same way when integrating a Verilog module in a VHDL top-module in Quartus: you basically just instantiate the Verilog module in the same way you would instantiate a VHDL module in the top-module and the rest will be handled by the IDE.
