13 years ago
Hilbert Transform
Hello, was wondering if anyone has implemented a Hilbert Transform on an FPGA? If so, can you share your comments or suggestions?
Respectfully,
joe
    An FPGA-based Hilbert transform is essentially a digital filter. However, they're not that useful in practice due to the asymmetry in its implementation.
    A Hilbert transform is often used to create an analytic signal, i.e., a complex-valued signal. In an FPGA, you typically create a complex-valued signal from a real-valued signal (eg., samples from an ADC) by demodulating the signal to complex-valued baseband, filtering, and decimating.
    What were you thinking of using the Hilbert transform for? I probably have a reference book here with more details if it really is a Hilbert transform you want to use.
    Cheers,
    Dave
    --- Quote Start ---
    Respectfully,
    joe
    --- Quote End ---
    I agree with Dave regarding demodulator alternative to Hilbert Transform in FPGAs but if you are interested I suggest looking at information given by xilinx or altera with their tools:
    Hilbert here:
    http://www.uccs.edu/~gtumbush/ise_10.1_docs/fir_compiler_ds534.pdf
    altera's equivalent discussion : google for "implementing signal processing functions in stratix..."
    edit:
    altera doc at: http://www.altera.co.uk/literature/hb/stx/ch_7_vol_2.pdf
    --- Quote Start ---
    Cheers,
    Dave
    --- Quote End ---
    Can you tell me the reference book for implementing Hilbert Transform on FPGA.
    killer
    --- Quote Start ---
    killer
    --- Quote End ---
    one way is to do fft then zero all negative bins then do ifft
    --- Quote Start ---
    --- Quote End ---
    I don't recall a specific book with an FPGA example, but I just had a quick look on Wikipedia ...
    http://en.wikipedia.org/wiki/hilbert_transform
    Scroll down to the "Discrete Hilbert transform" section and you'll see what I was talking about.
    What is it you are trying to do?
    Cheers,
    Dave
