GHe
8 years agoHi I have this piece of code: in a package i have the record declaration (unconstrained): modelsim is able to compile it, but quartus not (VHDL 2008). I tried 15.1 and 18 version . how can i overcome this without constraint the record in the package?
entity U1 is
generic
POS_CONFIG_1 : positive := 8;
POS_CONFIG_2 : positive := 75;
POS_CONFIG_3 : positive := 10;
POS_CONFIG_4 : positive := 48;
POS_CONFIG_5 : positive := 4
port
IN_REC_DVP_BUS : in DvpBus(data(POS_CONFIG_1-1 downto 0),
xpos(bwidth(POS_CONFIG_2+POS_CONFIG_3)-1 downto 0),
ypos(bwidth(POS_CONFIG_4+POS_CONFIG_5)-1 downto 0));
OUT_REC_DVP_BUS : out DvpBus(data(POS_CONFIG_1-1 downto 0),
CLK_0 : in std_logic ;
RST_0 : in std_logic
end entity U1;
type DvpBus is record
SAMP : std_logic;
VALID : std_logic;
DATA : std_logic_vector;
XPOS : unsigned;
YPOS : unsigned;
end record DvpBus;
Error (10410): VHDL Type Conversion error at u1.vhd(71): Type Conversion near text or symbol "DvpBus" must have one argument1 Reply
- Tricky
Quartus Prime Standard only ever had limited 2008 support, and unconstrained record types was never a supported feature.
Prime Pro has full 2008 support.
Only answer is to use prime pro, or constrain the record type definition.
