TKrum
8 years agoHex File for EPCQ-A
Hi everyone, i have a logic for Firmwareupdates using the Asmi Parallel IP for writing, with quartus generated *.hexout-Files, into the EPCQ. After porting to EPCQ-A and Regenerating IP and jic Prog...
TKrum
8 years agoThank you. I did everything as described in the Application Note. But I cant generate hexout-Files that are compatible with EPCQ-A. There must be a difference between EPCQ and EPCQ-A, so that the hexout-Files arent compatible.
I can generate hexout-Files from my Design with Quartus. I can write the hexdata with the Asmi Parallel IP into the EPCQ-A. I can read the data back, they are right. But when i reset my board the FPGA remains in reset.
