13 years ago --- Quote Start --- 1 - In the NIOS II IDE right click on your system library project. 2 - On the left hand side of the window that pops up, click on "C/C++ Build". 3 - Click on the "Tool Settings" tab. 4 - Click on the Preprocessor section of the NIOS II Compiler. 5 - Add the "ALT_USE_EPCS_FLASH" to the list of defined symbols. Jake --- Quote End --- Hi Jake, I am using Nios 12.SP2 web edition. But I can't find "tool setting" in this version. Do you have any idea? David
