17 years agoWDB is correct that enabling "small device drivers" for your system library will essentially disable the EPCS controller and it will fail to open. You can however still use the "small device drivers" option if you add the following macro to your system library build:
"-DALT_USE_EPCS_FLASH" To understand why, simply look at the file: C:\altera\81\ip\altera\sopc_builder_ip\altera_avalon_epcs_flash_controller\HAL\inc\altera_avalon_epcs_flash_controller.h You'll see the line: # if (!defined(ALT_USE_SMALL_DRIVERS) && !defined(ALT_SIM_OPTIMIZE)) || defined ALT_USE_EPCS_FLASH Good luck, Jake
