17 years agoi can't even do that can you help me with that. when i measure with the scope on the ports there is no activity on any port
//***************** while(1) { IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(EPCS_FLASH_CONTROLLER_0_BASE, 1 << 0); IOWR_ALTERA_AVALON_SPI_TXDATA(EPCS_FLASH_CONTROLLER_0_BASE, 0xAA); IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(EPCS_FLASH_CONTROLLER_0_BASE, 0 << 0); } //******************* I think that your problem is that you need to NOT, enable the small device drivers in the system library. i have the same problem and from the reading i figured that is the problem. I'm a newbe so i might be wrong.
