12 years agoI suggest you generate a 4-bit, registered, counter that generates the 16 different combinations of slot availability possible. Connect each bit of the counter to your p1-p4 module input signals.
There are several ways in which you could generate this stimulus - I'm not sure yours is one of them :oops: You might try this: module tb (); reg [3:0] p; integer i; initial begin p = 0; for (i=0; i<=15; i=i+1) # 10 p = p + 1; $stop(); end // Connect up your module here... endmodule The 4-bit register 'p' gives you the four individual signals you need to stimulate you module with.
