9 years agoHelp with porting a CUDA code to OpenCL
Hi everyone. I am porting a CUDA kernel to OpenCL kernel to execute it on a FPGA (Stratix V). The code looks very similar so it shouldn't be a problem except that this FPGA board supports only O...
9 years agoOk so the program is running perfectly on GPU. I have compiled the kernels used in the program and flashed them on the FPGA. Rebooted, checked with "aocl diagnose" that FPGA was communicating. used "aocl program" command to check. Then I runned the program on the FPGA and it gave me some access violation reading memory.... It is not the first time I run something on FPGA. What could it be?!
