9 years agoHelp with porting a CUDA code to OpenCL
Hi everyone. I am porting a CUDA kernel to OpenCL kernel to execute it on a FPGA (Stratix V). The code looks very similar so it shouldn't be a problem except that this FPGA board supports only O...
9 years agoApparently that kernel does run if make sequential. As soon as I run it as a parallel execution it fails. Yes I have made changes in the code for each type of execution.
So what I am thinking is a race condition when writing to the same array. Is that correct/possible? I am trying to use atomic functions to see if I can solve this problem but when I compile I get "note: candidate function has been explicitly made unavailable". What does it mean? I am using double variables in my code. Thanks
