9 years agoHelp with porting a CUDA code to OpenCL
Hi everyone. I am porting a CUDA kernel to OpenCL kernel to execute it on a FPGA (Stratix V). The code looks very similar so it shouldn't be a problem except that this FPGA board supports only O...
9 years ago --- Quote Start --- Unless you are converting the OpenCL error number incorrectly, "INVALID COMMAND QUEUE" has nothing to do with what is in your kernel; it is because you have some issue in your host code. Find the OpenCL function in the host that is throwing this error and fix it. --- Quote End --- I have used clerrors.h from the tests project of the fpga board to decode the error. Also if I run the kernel with some data it doesn't fail. If I do with other data it does fail. I am not sure why. Data doesn't look to be corrupted.
