9 years agoHelp with porting a CUDA code to OpenCL
Hi everyone. I am porting a CUDA kernel to OpenCL kernel to execute it on a FPGA (Stratix V). The code looks very similar so it shouldn't be a problem except that this FPGA board supports only O...
9 years agoIf your issue is with general OpenCL usage, and not problems specific to using OpenCL on FPGAs, I recommend searching online or consulting with stackoverflow. You could take a look at the following pages for starters:
https://github.com/vtsynergy/cu2cl https://www.sharcnet.ca/help/index.php/porting_cuda_to_opencl
