16 years agoHelp with Multi-bit Generic Multiplexer
I'm write code in VHDL to implement a multi-bit generic multiplexer. When I compile it, there was an error that I had no idea how to fix. Can anyone help me? Thank you in advance!
Error message: Error (10500): VHDL syntax error at GenericMultiplexer.vhd(26) near text ":="; expecting "(", or "'", or "." line 26 is : temp := temp*2 + sel(i); library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; package decoder is type matrix is array ( natural range <> ) of std_logic_vector ( 7 downto 0 ); end decoder; library ieee; use work.decoder.all; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity GenericMultiplexer is generic ( n : integer := 8 ); port ( input : in matrix (2**n-1 downto 0); sel : in bit_vector ( n-1 downto 0 ); output : std_logic_vector ( 7 downto 0 )); end GenericMultiplexer; architecture behavior of GenericMultiplexer is variable temp : integer := 0; begin G1: for i in sel'range generate temp := temp*2 + sel(i); end generate; output <= input ( temp ); end behavior;
