12 years agoBut somehow you have misscopied it (or modified it)
There is an extra "begin" on line 97, and the first debounce process has (clk) as a sensitivity list when it should have no sensitivity list. Otherwise the code is the same. It also contains extra comments that Kaz's doesnt have either. I suspect you didnt copy it - you tried to merge it into your own copy.
