12 years ago --- Quote Start --- here is the code. Note it will fail your simulation unless you change the pattern of keys to let counter reach 25000 clocks so it is suitable for hardware mostly.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.ALL;
entity uppgift_dorr is
port( clk : in std_logic; --clock signal
reset_n : in std_logic; --reset signal
key_0, key_1, key_2, key_3 : in std_logic;
LEDR : out std_logic_vector(1 downto 0);
LEDG : out std_logic_vector(1 downto 0)
end uppgift_dorr;
architecture Behavioral of uppgift_dorr is
--Defines the type for states in the state machine
type state_type is (closed,opened,locked,error);
--Declare the signal with the corresponding state type.
signal Current_State, Next_State : state_type;
signal count_0 : unsigned(17 downto 0) := (others => '0');
signal count_1 : unsigned(17 downto 0) := (others => '0');
signal count_2 : unsigned(17 downto 0) := (others => '0');
signal count_3 : unsigned(17 downto 0) := (others => '0');
signal key_0_d,key_0_final: std_logic;
signal key_1_d,key_1_final: std_logic;
signal key_2_d,key_2_final: std_logic;
signal key_3_d,key_3_final: std_logic;
begin
--debounce
process
begin
wait until clk = '1';
key_0_d <= key_0;
if key_0 = key_0_d then
count_0 <= count_0 +1;
else
count_0 <= (others => '0');
end if;
if count_0 > 250000 then -- about 5 msec bounce time
key_0_final <= key_0;
end if;
key_1_d <= key_1;
if key_1 = key_1_d then
count_1 <= count_1 +1;
else
count_1 <= (others => '0');
end if;
if count_1 > 250000 then -- about 5 msec bounce time
key_1_final <= key_1;
end if;
key_2_d <= key_2;
if key_2 = key_2_d then
count_2 <= count_2 +1;
else
count_2 <= (others => '0');
end if;
if count_2 > 250000 then -- about 5 msec bounce time
key_2_final <= key_2;
end if;
key_3_d <= key_3;
if key_3 = key_3_d then
count_3 <= count_3 +1;
else
count_3 <= (others => '0');
end if;
if count_3 > 250000 then -- about 5 msec bounce time
key_3_final <= key_3;
end if;
end process;
-- Synchronous Process
p0: process(clk, reset_n)
begin
if( reset_n = '0' ) then --Synchronous Reset
Current_State <= opened;
elsif (rising_edge(clk)) then --Rising edge of Clock
Current_State <= Next_State;
end if;
end process;
-- Combinational Process
p1: Process(Current_State, key_0_final, key_1_final, key_2_final, key_3_final)
begin
case Current_State is
when opened =>
LEDG <= "01"; LEDR <= "00";
if ( key_0_final = '0' ) then
Next_State <= closed;
end if;
when closed =>
LEDG <= "10"; LEDR <= "01";
if ( key_1_final = '0') then
Next_State <= opened;
elsif (key_2_final = '0') then
Next_State <= locked;
end if;
when locked =>
LEDG <= "00"; LEDR <= "10";
if ( key_3_final = '0') then -- Låser upp dörren
elsif(key_2_final = '0')then -- tray to lock, error
Next_State <= error;
end if;
when error =>
LEDG <= "11"; LEDR <= "11";
end case;
end process;
end Behavioral;
--- Quote End --- ---------------------------------------------------------- Hi Kaz, i lack words to show my appreciation thank you so much for the help i am going to test it on the DE2 board.
