12 years ago --- Quote Start --- You need to trace back the problem. You can show all the states on the waveform. Have you added all the signals from the unit under test? --- Quote End --- ------------------------------ Yes i have done so i have added all the unit under test. I am trying to see how i can figure out the problem, Ooops!!!
