8 years agoHelp with a VHDL code - using an array
Hello! I want to use an array in order to check if my coordinates are correct, according to certain conditions. The coordinates represent a beginning point of a picture I will print on the scre...
8 years agoYou can define a generic so that the range can be set when you instantiate the component.
Currently the loop does nothing because remember that all the code will be executed on every clock cycle. This is hardware description, not software programming. Did you draw the circuit before you wrote the code?
