10 years ago
[HELP] VHDL "cant infer register."
The Quartus is detecting an error in my code, the error is this:Error (10821): HDL error at state_machine.vhd(27): can't infer register for "atual" because its behavior does not match any supported register modelI do not know how to solve. I need to use "case" and "type" because my teacher asked.I ask for help to solve. The code is below.Thank you.
--DECLARAÇÃO DE BIBLIOTECAS
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.NUMERIC_STD.ALL;
--DECLARAÇÃO DA ENTIDADE
ENTITY state_machine IS
PORT(
clk,d: IN STD_LOGIC
END ENTITY state_machine;
--DECLARAÇÃO DA ARQUITETURA DA ENTIDADE
ARCHITECTURE behavioral OF state_machine IS
TYPE estado IS(amostrar,naoamostrar);
SIGNAL cancannot: STD_LOGIC;
SIGNAL atual: estado := naoamostrar;
BEGIN
contandoeamostrando: PROCESS(clk,d,atual)
VARIABLE count: INTEGER := 0;
BEGIN
CASE atual IS
WHEN amostrar =>
cancannot <= '1';
IF(RISING_EDGE(clk)) THEN
count := 0;
atual <= naoamostrar;
END IF;
WHEN naoamostrar =>
cancannot <= '0';
IF(count<3333333) THEN
count := count + 1;
ELSE
atual <= amostrar;
END IF;
END IF;
END CASE;
END PROCESS;
END ARCHITECTURE;
