12 years agoHelp: Quartus II Internal Error: Sub-system: QGQ - no Change Manager Window
I am using Quartus II 64 Bit Version 13.0. I run a project while I was running the same project in Quartus II 64 Bit Version 8.0.
I did that because I have just installed the Version 13.0 and I am not familiar with it. The problem is that unfortunately the quartus Version 13.0 presented this error <internal_error> <executable>quartus_map.exe</executable> <sub_system>MEM</sub_system> <error>*** Fatal Error: Out of memory in module quartus_map.exe (14183 megabytes used)</error> <date>Tue Jul 30 17:41:03 2013</date> <version>Version 13.0.0 Build 156 04/24/2013 SJ Web Edition</version> </internal_error> Then, I closed the Version 13.0 and I continued only with the Version 8.0. Now, I tried to open the Quartus II 64 Bit Version 13.0 and it showed this error: Internal Error: Sub-system: QGQ, File: /quartus/sys/qgq/qgq_main_window.cpp, Line: 288 no Change Manager Window Stack Trace: 0x5dec: QGQ_MAIN_WINDOW::QGQ_MAIN_WINDOW + 0xe2c 0x7654: sys_qgq_create_frame_wnd + 0x54 0x11f44: QUI_FRAME_MGR::create_frame_wnd + 0x1a4 0x132bf: QUI_FRAME_MGR::create_main + 0x2f 0x74d6: QUI_APP::init_instance + 0x3e6 0x8997: QGQ_APP::init_instance + 0xe7 0x4ae8: msg_exe_fini + 0x58 0x522c: msg_exe_fini + 0x79c 0x1524: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194 0x5e0f: msg_exe_main + 0x8f 0x1652c: BaseThreadInitThunk + 0xc 0x2c520: RtlUserThreadStart + 0x20 End-trace Quartus II 64-Bit Version 13.0.0 Build 156 04/24/2013 SJ Web Edition I have to say that I have not the Version 8.0 open as I had closed it. Moreover, I uninstalled the Version 13 and reinstalled it again but the problem has not disappeared. Please help me. What is the problem and I cannot open it?
