13 years agohelp please speech recognition using VHDL
i get this code and i was really needed to implement an speech recognition project using vhdl code...i have trained it and i want to upload in DE2 board but am getting this error so please help me out...if you know where i can get the full code u can help me with it...your help will be appreciated...thanks in advance.
library ieee, std, work; use ieee.std_logic_1164.all, std.textio.all, work.all; entity readspeech is port (speech_length : out integer; speech_read : out std_logic := '0'); end readspeech; architecture only of readspeech is signal N : integer := 10000; -- make sure this number matches the -- number of samples in your speech -- data file type speechvector is array (1 to N) of real; signal speech : speechvector ; begin READDATA: process file data_file : text IS IN "down.dat"; variable buf : line; variable speech_length_t : integer := 0; variable real_data : real; begin readline(data_file,buf); -- read comment line (ignore) readline(data_file,buf); -- read line read(buf,speech_length_t); -- number of data points for i in 1 to speech_length_t loop readline(data_file,buf); -- read a line read(buf,real_data); -- get the data speech(i) <= real_data; -- store to speech vector end loop; file_close(data_file); speech_read <= '1'; speech_length <= speech_length_t; wait; end process; end only; ..... after i run the code am getting this message...and the problem i make it red and underline. cannot synthisize non constant real objects or values
