10 years agoHelp needed in VHDL Testbench
Hi all, I have written the testbench file in such a manner that I need to perform updowncounting and downcounting based on the value of dir_s. But the problem is, when I execute the code, the di...
10 years ago@tricky,
I have tried all possibilities and I find that the old_phi_e_s is not pushed to phi_e_gr_o as well as phi_e_i is not pushed to phi_e_gr_o. This is the waveform I obtain when I run the simulation. https://www.alteraforum.com/forum/attachment.php?attachmentid=12710 Also I have changed my testbench because there was a kind of mistake in the design. This is my testbench code:wait for 10 ns;
reset_n_i <= '1';
wait for 15 ns;
enable_i <= '1';
phi_e_i <= "101010101111010101101010101101010101";
thresh_i <= "10000000";
wait for 10 ns;
phi_e_i <= "111010101101010101010101010101010101";
thresh_i <= "00010110";
wait for 10 ns;
phi_e_i <= "100000000000000000010101010101010101";
thresh_i <= "00010101";
wait for 20 ns;
phi_e_i <= "110101010101010101010101111110101010";
thresh_i <= "01110000";
wait for 15 ns;
phi_e_i <= "000000000000000000000000001010110101";
thresh_i <= "01111111";
wait for 1 ms;
reset_n_i <= '0';
wait for 1 ms;
reset_n_i <= '1';
wait for 1 ms;
enable_i <= '0';
wait for 1 ms;
enable_i <= '1';
wait for 1 ms;
assert False report "End simulation!" severity Failure;
end process;
delay_rst_s <= reset_n_i after 1 ns;
new_thresh_s <= std_logic_vector(thresh_i & "0000000000000000000000000000");
p_check_outp: process(delay_rst_s, clk_128meg_i)
begin
if (delay_rst_s = '0') then
old_phi_e_s <= (others => '0');
assert phi_e_gr_o = "000000000000000000000000000000000000" report "Output not set to default value when reset_n_i= 0" severity error;
elsif (clk_128meg_i'event and clk_128meg_i = '0')then
if (enable_i = '1') then
old_phi_e_s <= phi_e_i;
if (abs(signed(phi_e_i) - signed(old_phi_e_s)) >= to_integer(unsigned(new_thresh_s))) then
assert phi_e_gr_o = old_phi_e_s report "Wrong output: phi_e_gr_o should be equal to old phi_e_i" severity error;
elsif (abs(signed(phi_e_i) - signed(old_phi_e_s)) < to_integer(unsigned(new_thresh_s))) then
assert phi_e_gr_o = phi_e_i report "Wrong output: phi_e_gr_o should be equal to phi_e_i" severity error;
end if;
else
assert phi_e_gr_o = "000000000000000000000000000000000000" report " Output not set to default value when enable_i= 0" severity error;
end if;
end if;
end process;
. Please help me to solve this issue. I am really fed up of why I am not getting the output
