10 years agoHelp needed in VHDL Testbench
Hi all, I have written the testbench file in such a manner that I need to perform updowncounting and downcounting based on the value of dir_s. But the problem is, when I execute the code, the di...
10 years ago --- Quote Start --- Yes, you can (and will need to ) write a port map. But you cannot run the simulation as there is nothing to bind the component to. A component just tells the compiler about an entity interface. --- Quote End --- What if I need to run the simulation
