8 years agoHelp multiplier vhdl
Hi everyone! I've some problems with a design, I have to Design an algorithmic state machine to implement a parallel series multiplier for eight-bit numbers encoded in SM (Sign-Magnitude). The mul...
8 years agoThat is because + and & operators have equal precedence, so it is doing the add followed by concatenate, giving you a 17 bit result (ie. you code is actaully y := (Y+temp)& "0"; )
You need to put () in to fix the precedence: y := y + (temp&"0");
