8 years agoHelp multiplier vhdl
Hi everyone! I've some problems with a design, I have to Design an algorithmic state machine to implement a parallel series multiplier for eight-bit numbers encoded in SM (Sign-Magnitude). The mul...
8 years ago --- Quote Start --- You need to show what have you done so far and where in design stage you want help. The 8 bit sign&magnitude can be any value from 0111 1111 to 1111 1111 when you multiply you do that per bit then add up as in primary school multiplication. You can ignore sign bit as you can conclude that at the end, for demo assume you have: 1) 111 1111 2) 111 1101 thus you multiply 1 by 111 1111 and you get 111 1111 then you multiply by zero which results in zero, shift one bit... xxxxxxx111 1111 xxxxxx000 0000 xxxxx111 1111 xxxx111 111 xx111 1111 x111 1111 111 1111 ------------------------ after 7 multiplications you add all to get result then decide sign bit --- Quote End --- Thank you kaz, but how can I do that in VHDL?? I know how I have to do the operation, but I don't know how to create the register in VHDL. Right now, I have this: library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.std_logic_unsigned.all; use IEEE.numeric_std.all; entity reg_des is port ( multiplicador: in std_logic; multiplicando: in std_logic_vector (7 downto 0); registro7: out std_logic_vector (7 downto 0); registro6: out std_logic_vector (7 downto 0); Q7: out std_logic; resultado: out bit_vector (15 downto 0); clk: in std_logic; reset: in std_logic); end reg_des; architecture behavioral of reg_des is begin reg_des : process (multiplicador, clk, reset) variable Q : std_logic_vector (8 downto 0); begin if reset = '1' then Q:= "000000000"; else if clk'event and clk = '1' then for i in 0 to 7 loop Q(i) := Q(i+1); if i = 0 then registro7(7) <= Q(i) and multiplicando(7); end if; if i = 1 then registro7(6) <= Q(i) and multiplicando(7); registro6 (7) <= Q(i-1) and multiplicando(6); end if; if i = 2 then registro7(5) <= Q(i) and multiplicando(7); registro6 (6) <= Q(i-1) and multiplicando(6); end if; if i = 3 then registro7(4) <= Q(i) and multiplicando(7); registro6 (5) <= Q(i-1) and multiplicando(6); end if; if i = 4 then registro7(3) <= Q(i) and multiplicando(7); registro6 (4) <= Q(i-1) and multiplicando(6); end if; if i = 5 then registro7(2) <= Q(i) and multiplicando(7); registro6 (3) <= Q(i-1) and multiplicando(6); end if; if i = 6 then registro7(1) <= Q(i) and multiplicando(7); registro6 (2) <= Q(i-1) and multiplicando(6); end if; if i = 7 then registro7(0) <= Q(i) and multiplicando(7); registro6 (1) <= Q(i-1) and multiplicando(6); end if; if i = 8 then registro6 (0) <= Q(i-1) and multiplicando(6); end if; end loop; Q(8):=multiplicador; Q7 <= Q(7); end if; end if; end process; end behavioral; ------------------------------------------------------ Is this the correct way to do it?? Thank you!
