11 years ago[HELP ] VHDL Parking Lot
Hello guys, i'm not idea how resolve this problem, please help me parking lot, shown in the Fig. 2, has space for 10 cars. There is only one entrance to the parking lot, consequently one car at...
11 years agoI can try being a bit more constructive....
The reason why I say you should begin with the testbench is that it makes you think about what kind of inputs your system will have and how it should react. Start with something basic. Draw a timing diagram of the signals from the two sensors when a car enters the parking lot. You need to have the whole event, from when the car is completely outside the parking until when it is fully inside. Similarly draw the diagram for when a car exits the parking lot. Then write two VHDL procedures that generate the sensor signals for both events. Then you can write your testbench. The parking starts empty, and for example call 9 times the procedure that simulates a car entering the parking lot. During all that time the testbench will also check that the "free" light is always on and will generate an error if it doesn't. Then call a 10th time the car enter simulating procedure, and check that the "free" light turns off, and the "full" light turns on (allowing a small delay before checking). Then simulate a car going outside of the parking, and check that the "full" light turns off and the "free" light turns on. This can be your first test bench to check your code. Ideally you will want to simulate other cases, with several cars going out and in again, just to check that your code behaves correctly in different situations. Once you have that, and you have a good idea on how the sensors work, you can begin designing your main VHDL code. Note that if you want something that synthesizes, you will probably need a clock, generated in the test bench.
