8 years agoHelp - Creating alarm clock with modulo counter - System verilog
I am trying to create an alarm clock using a Terasic CycloneV fpga. I need to be able to set the time and an alarm. Right now I'm unable to get the clock to reset at 24 hours. I have attached the mod...
8 years agoThe reason for the always_ff block not working is because you'v used the bit-wise AND (&) operator and not the logical AND (&&). Change the '&' to '&&' and try. It will trigger this time.
/*this is the part that doesn't work
always_ff @(posedge oneSecondEnable) begin
if (rollHourTens ==2 & rollHourOnes==4) begin <------ Change this to logical && from the bitwise &
reset;
end
end
