8 years agoHelp - Creating alarm clock with modulo counter - System verilog
I am trying to create an alarm clock using a Terasic CycloneV fpga. I need to be able to set the time and an alarm. Right now I'm unable to get the clock to reset at 24 hours. I have attached the mod...
8 years agoI suggest you need to work out a mechanism to reset the clock at the correct time. Have you tried drawing the circuit (on paper) to work out how you're going to connect the reset?
