8 years agohelloworld issue on arria10Gx development kit
Hi, I am trying to compile and run hello_world example of OpenCL SDK on Arria10Gx development board. Example fails to run with below error code. kindly check below steps and comment on any wrong...
8 years ago --- Quote Start --- Then there must be something wrong with your environmental variables somewhere. If the compiled host code is detecting your CPU, but not your FPGA, it means it is being compiled against some SDK other than Altera's, or that your FPGA is not being detected and hence, the host code is using the CPU. Have you made sure your board is detected correctly? e.g. does your board pass "aocl diagnose"? --- Quote End --- Hello HRZ, With multiple trials of reboot and "sudo jtagconfig", able to get on-board JTAG interface. Host commands lsusb, lspci and jtagconfig works and lists Arria10Gx board. But now when I run application its giving different error. mobiliya@mobiliya:~/intelFPGA_pro/17.1/quartus/bin$ jtagconfig 1) USB-BlasterII [3-13] 02E660DD 10AX115H1(.|E2|ES)/10AX115H2/.. 020A40DD 5M(1270ZF324|2210Z)/EPM2210 mobiliya@mobiliya:~/opencl_examples/vectoradd/vector_add$ lspci | grep -i altera 06:00.0 Processing accelerators: Altera Corporation Device 2494 (rev 01) mobiliya@mobiliya:~/opencl_examples/helloworld/hello_world$ bin/host Querying platform for info: ========================== CL_PLATFORM_NAME = Intel(R) FPGA SDK for OpenCL(TM) CL_PLATFORM_VENDOR = Intel(R) Corporation CL_PLATFORM_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 17.1 ERROR: CL_DEVICE_NOT_FOUND Location: ../common/src/AOCLUtils/opencl.cpp:356 Query for number of devices failed --- Quote End ---
