8 years agohelloworld issue on arria10Gx development kit
Hi, I am trying to compile and run hello_world example of OpenCL SDK on Arria10Gx development board. Example fails to run with below error code. kindly check below steps and comment on any wrong...
8 years agoIf you could initially program the FPGA with your cable, then the OpenCL runtime should also be able to do so. Try running "quartus_pgm -a". If your board is listed, it should work. If not, kill the jtagd service and then run "quartus_pgm -a" as root. It is important that the command is ran as root for the first time after machine boot or else, the cable will not be detected. After that, the cable will be detected regardless of which user is running the command.
