8 years agohelloworld issue on arria10Gx development kit
Hi, I am trying to compile and run hello_world example of OpenCL SDK on Arria10Gx development board. Example fails to run with below error code. kindly check below steps and comment on any wrong...
8 years ago --- Quote Start --- Copy "*Quartus_Dir*/hld/Altera.icd" to "/etc/OpenCL/vendors/". --- Quote End --- Thanks. With this I am able to run hello_world sample application with below error. Querying platform for info: ========================== CL_PLATFORM_NAME = Intel(R) FPGA SDK for OpenCL(TM) CL_PLATFORM_VENDOR = Intel(R) Corporation CL_PLATFORM_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 17.1 Querying device for info: ======================== CL_DEVICE_NAME = a10gx : Arria 10 Reference Platform (acla10_ref0) CL_DEVICE_VENDOR = Intel(R) Corporation CL_DEVICE_VENDOR_ID = 4466 CL_DEVICE_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 17.1 CL_DRIVER_VERSION = 17.1 CL_DEVICE_ADDRESS_BITS = 64 CL_DEVICE_AVAILABLE = true CL_DEVICE_ENDIAN_LITTLE = true CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 32768 CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 0 CL_DEVICE_GLOBAL_MEM_SIZE = 2147483648 CL_DEVICE_IMAGE_SUPPORT = true CL_DEVICE_LOCAL_MEM_SIZE = 16384 CL_DEVICE_MAX_CLOCK_FREQUENCY = 1000 CL_DEVICE_MAX_COMPUTE_UNITS = 1 CL_DEVICE_MAX_CONSTANT_ARGS = 8 CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 536870912 CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3 CL_DEVICE_MEM_BASE_ADDR_ALIGN = 8192 CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 1024 CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 4 CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 2 CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0 Command queue out of order? = false Command queue profiling enabled? = true Using AOCX: hello_world.aocx MMD INFO : [acla10_ref0] PR base and import compile IDs do not match MMD INFO : [acla10_ref0] PR base ID currently configured is 0x47e4097c MMD INFO : [acla10_ref0] PR import compile expects ID to be 0x2ca189ab MMD INFO : [acla10_ref0] Falling back to JTAG programming instead of PR MMD INFO : Autodetect Cable not found!! MMD INFO : setting Cable to default value 1 MMD INFO : setting Device Index to default value 1 MMD INFO : executing "quartus_pgm -c 1 -m jtag -o "P;reprogram_temp.sof@1"" Error (213013): Programming hardware cable not detected Error (213013): Programming hardware cable not detected Error (213013): Programming hardware cable not detected mmd program_device: Board reprogram failed Kernel initialization is complete. Launching the kernel... MMD FATAL: acl_pcie.cpp:71: can't find handle -1 -- aborting host: acl_pcie.cpp:71: ACL_PCIE_DEVICE* get_pcie_device(int): Assertion `0' failed.
