11 years ago --- Quote Start --- Problem solved. It was bug with CvP, Picocomputing make update to BSP and flash.pl script. After this, hello_world example has run successfull. Thank you! --- Quote End --- Hi Breaknus, I have a similar problem with you. Can you specify how you solved this problem? Thank you!! Yuxuan
