HelloWorld-Error: Compiler Error, not able to generate hardware
Hi YY,
Thanks for locating this problem. Finally, I find this problem caused by lacking the json library in python. Thanks a million.
However, there was another problem:
Error (213009): File name "output_files/afu_fit.green_region.pmsf" does not exist or can't be read
Error: Quartus Prime Convert_programming_file was unsuccessful. 1 error, 0 warnings
Error (23031): Evaluation of Tcl script a10_partial_reconfig/flow.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 7 errors, 3314 warnings
in "quartus_sh_compile.log", it shows:
Info: Command: quartus_cpf -c output_files/afu_fit.green_region.pmsf output_files/afu_fit.green_region.rbf
Info: Using INI file /home/wei/test_file/exm_opencl_hello_world_x64_linux/hello_world/bin/hello_world/build/quartus.ini
Error: Peak virtual memory: 401 megabytes
Error: Processing ended: Fri Jun 21 05:58:45 2019
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:00
Error: Peak virtual memory: 702 megabytes
Error: Processing ended: Fri Jun 21 05:58:46 2019
Error: Elapsed time: 00:34:15
Error: Total CPU time (on all processors): 03:01:48
ERROR: pll timing script failed.
Do you have any advise about that?
