WWang76
7 years agoHelloWorld-Error: Compiler Error, not able to generate hardware
Hi guys, I want to test the OpenCL driver on pac_a10 board, but when I run the sample code, I meet a problems: aoc: Environment checks are completed successfully. aoc: Cached files in /var/tmp/aoc...
KhaiChein_Y_Intel
7 years agoHi WWang76,
It seems like you see similar error in
https://forums.intel.com/s/question/0D70P000006G4HL/error-compiling-helloworldcl-with-aoc?s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&emkind=chatterCommentNotification&s1uid=0050P000008IfXG&emtm=1554193950089&fromEmail=1&s1ext=0
Can you try the workaround suggested in this thread?
sudo apt-get install python-jsonschema
Referring to
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf
, Intel FPGA SDK for OpenCL requires no additional licenses. It is supported with the Intel Quartus Prime Pro/Standard Edition software and the Pro/Standard edition software require license.
