WWang76
7 years agoHelloWorld-Error: Compiler Error, not able to generate hardware
Hi guys, I want to test the OpenCL driver on pac_a10 board, but when I run the sample code, I meet a problems: aoc: Environment checks are completed successfully. aoc: Cached files in /var/tmp/aoc...
KhaiChein_Y_Intel
7 years agoHi WWang76,
I tried to run aoc command without the license. The error occurred is different from the error we have here. I believe this error is not related to the license.
- WWang767 years ago
Hi YY,
Thank you a lot.
Is that meaning if I fix the error, I still need to have a full license to run aoc command?
