WWang76
7 years agoHelloWorld-Error: Compiler Error, not able to generate hardware
Hi guys, I want to test the OpenCL driver on pac_a10 board, but when I run the sample code, I meet a problems: aoc: Environment checks are completed successfully. aoc: Cached files in /var/tmp/aoc...
KhaiChein_Y_Intel
7 years agoHi WWang76,
Could you share the bin/hello_world/quartus_sh_compile.log or hello_world.log file?
May I know which version you are using?
WWang76
7 years agoHi Kyeoh,
There is the "hello_world.log" file, and the he "quartus_sh_compile.log" just has one line:
ERROR: packager tool failed to run. Check installation. Aborting compilation!
I tried:
Quartus Prime Analysis & Synthesis
Version 17.1.1 Build 273 12/19/2017 Patches 1.02dcp,1.36,1.38 SJ Pro Edition
Copyright (C) 2017 Intel Corporation. All rights reserved.
and
aocl 17.1.1.273 (Intel(R) FPGA SDK for OpenCL(TM), Version 17.1.1 Build 273, Copyright (C) 2017 Intel Corporation)
I also tried the version 18.1(both). but nothing changed.
the version of BSP is a10_gx_pac_ias_1_2_pv
