CATHA2
7 years agoHello, I am new to Altera and Quartus and I needed help. I'm using Altera EPM3032ATC44-10 on my hardware development board. I have Quartus II 13.0.
Hello, I am new to Altera and Quartus and I needed help. I'm using Altera EPM3032ATC44-10 on my hardware development board. I have Quartus II 13.0. I wrote a code in VHDL for one of my company's p...
ak6dn
7 years agoI have a design based on an Altera/Intel EPM3064ALC44-7, so it very similar to yours.
You will use the .pof files to program CPLD devices.
An .sdc file for a CPLD can usually be pretty simple. For my device I use this:
# Input 20MHz reference clock
create_clock -period 50.0 -name CLK [get_ports {CLK}]
# Input delays
set_input_delay -clock CLK -max 4.0 [all_inputs]
set_input_delay -clock CLK -min 1.0 [all_inputs]
# Output delays
set_output_delay -clock CLK -max 4.0 [all_outputs]
set_output_delay -clock CLK -min 1.0 [all_outputs]That's it for the .sdc file. I use Quartus 13.0sp1.
Do you run your code thru a simulation testbench? I highly recommend it, it will save a lot of headaches like you are seeing.
CATHA2
7 years agoThanks. Is that all for the .sdc file? I have been trying doing simulations too but the outputs on the simulation are different from what I am seeing in reality.
