8 years agohdmi cyclone 2...
Hi I'm new here. I've recently bought a cheap cyclone 2 dev board, EP2C5T144 with the soul intent can I produce a picture via HDMI (DVI) expressed from the IO pins of the fpga directly, lookin...
8 years agoHi Solidcore,
1. Check the properties of the monitor and adjust the properties of the monitor as per code or modify the code (Resolution,Vsync,Hsync). 2. Check the monitor is using interlace or progressive scanning. 3. Check the Timing Vsync, Hsync, Pexel clock & porch. 4. Only write a code for solid pattern i.e white/black. Without proper sync signals monitor will not display and it will go to sleep mode. For sample full projects at terasic website. https://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=68&no=582&partno=3 Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
