8 years agohdmi cyclone 2...
Hi I'm new here. I've recently bought a cheap cyclone 2 dev board, EP2C5T144 with the soul intent can I produce a picture via HDMI (DVI) expressed from the IO pins of the fpga directly, lookin...
8 years agoYou mention generating a 250MHz clock from you PLL. Running much, or possibly anything, on Cyclone II at that speed is likely to be tricky.
How much logic do you run at this speed? Have you added timing constraints to your design? Does it meet them? The Neo Geo MVS project you refer to doesn't appear to be running anything at that speed... Cheers, Alex
