11 years agoHDL Testbench in ModelSim Altera Edition
I have been a Xilinx user in the past and I'm currently moving a design from a Xilinx part to an Altera part and having some issues with simulation. I have a VHDL testbench that runs flawlessly in t...
11 years agoModelsim is a universal simulator - you can simulate code for any system.
I suggest pulling out the user guide and learning how to use it in command line mode - its quite straight forward and can be scripted for larger runs. In the command line:
cd <your working directory>
# make the work library
vlib work
# compile all the files
vcom file1.vhdl
vcom file2.vhdl
# or if you have verilog
vlog file3.v
# now start a simulation
vsim my_top_level
# run it for some time
run 1 us
# start simulation over
restart -f
for other libraries, you can use vlib <libraryname> to create them for already compiled libraries (in modelsim) vmap <library_name> <path to library> This is the base for all simulations. It will do you well to learn it.
