10 years agoHaving problems test benching with Model Sim from Quartus, any ideas?
// This is the test bench `timescale 1 ps/ 1 ps module sum_fix (valor_a,valor_b,result_fx,select); input [7:-8] valor_a,valor_b; output reg [8:-8] result_fx; input select; al...
10 years agoI already fixed it, problem is that module name has to be the same that the file name, same than testbench file name in setting files. I have to say the whole proceed of Quartus Test bench is horrible, Xilinx is much more intuitive.
For example, since I have started learning Quartus-modelsim, I have to constantly launch and close, launch and close, otherwise I receive the message "error deleting "misim_transcript" ,permission denied. Check the Nativelink log file, C:/altera/15.0/....for detailed error message. I wish to know if this is normal, or is it me that I'm handling the software correctly.
