18 years agoMy guess is you have a timing problem. It's not bringing the signals out that's causing the problem, it's the fact that you have a different fit and therefore different timing. That's usually what the problem is in those situations, and they're a pain to debug for that very reason(SignalTap and SignalProbe can be run on post-fit netlists, which is harder to work with, but allows you to get around this issue.)
