10 years agoHard DDR3 Controller Fitting Problem on Cyclone V
Hi I have generated the DDR3 controller IP from IP Catalogue, using Quartus Prime v15.1; It generated an example design project too. After I assign my DDR3 pins to the FPGA pins & run the "..._p...
10 years agoAccording to Altera Cyclone V pin-out file, the HMC pins are fixed and the address_bus[13] MUST be tied to C8 (for my device part number), so this is the problem & should be corrected.
Thanks gj_leeson.
