10 years agoHard DDR3 Controller Fitting Problem on Cyclone V
Hi I have generated the DDR3 controller IP from IP Catalogue, using Quartus Prime v15.1; It generated an example design project too. After I assign my DDR3 pins to the FPGA pins & run the "..._p...
10 years agoThanks gj_leeson
My FPGA part is 5CEFA4F23. What was your FPGA part? This could help me understand if I am verifying everything correctly. Also I could verify if my problem is the same. Actually this is somewhat strange to me. In the "External Memory Interface Handbook" on Table 1-7 the only Cyclone V parts which could support DDR3 controller are the following: 5CGTD9, 5CEA9, 5CGXC9, 5CEA7, 5CGTD7, 5CGXC7 My part (5CEFA4F23 with 484 pins) has not been listed there! On the other hand on "Cyclone V Product Table" and "Cyclone V Device Overview" all parts of 5CE category support DDR3 Controllers!!!! How did you identify the root of your problem? Thank you
