RMcKe2
7 years agoHanging compilation- analysis and synthesis does not progress past 47%
I am currently unable to compile- compilation hangs specifically at 47% (or occasionally 65%) completion of the "Analysis and Synthesis" step. Compilation will not continue past these points, even if...
sstrell
7 years agoThe first thing to try is to close Quartus and trash the db and incremental_db folders for the project. Then reopen Quartus and try recompiling.
#iwork4intel
RMcKe2
7 years agoThis did seem to do the trick- Great to know going forward. Thank you very much for the assistance!
Additionally valuable to note is that the issues that I encountered may be a byproduct of using Github as a means of version control- potentially due to the .gitignore file that I use that disregards both the db and incremental_db folders.
